Hi all! I've got an 04 STi and I recently got a new clutch and front/rear shifter bushings. I found out during the install that the u-joint was busted on my driveshaft and I need to replace the whole thing. After checking prices and reading other DSS threads I'm thinking about a DSS aluminium driveshaft for about $480. I'm also looking as getting a rear diff crossmember bushing, and doing a tranny/diff fluid change with redline oil and not the recommended subaru oil. I've read that the DSS driveshafts are sometimes unbalanced and it may need to be sent back to the supplier to balance it. I also read that there will be some minor hammering of the DS tunnel to make it fit. I just wanted some opinions on what I'm doing, and some stories from people who were in a similar situation. Budget is a concern. Are there any other things I should look at doing while I'm getting this done? I've been having some trouble getting into 1st and 2nd gear, especially when the car is cold. I'm hoping the fluid changes will remedy that some.
